I'm assuming by "idle" you mean regardless of whether you run the engine? Also, is it correlated to rainfall in any way? In any case, here are a few things you could check -
1) The keel stepped mast will let water in whenever it rains. The amount of water depends on how well the boot at the cabin top is sealed, but there will likely always be some.
2) Are the hoses from the cockpit scuppers included in those that you checked?
3) I know you said the thru hull valves look fine, but what about the backing plates? The galley sink in particular has a backing plate that was quite well hidden by the hull liner on ours.
4) Have you inspected the deck fittings and hardware. Some that i remember as potentially problematic are the pushpit stantions and helm.
5) Do you see any water just in front of the engine (below the oil pan and fiberglass basin). There is a weep hole there that goes into the bilge. If you have water coming into the bilge from aft, then you may be able to trace it from around that weep hole. Also if that weep hole is partially clogged it may be letting the water into the bilge slowly, making you think you have an ongoing leak but really just holding water from some previous event.
6) Does your ice box drain into the bilge? Ours had a hand pump into the sink but some didn't.
