My boat, an 89 Hunter Legend 37, has three bilges. One is the boat bilge, the area below the floor in the main cabin where the keel bolts are located. This bilge has a pump and float switch. Second is the engine bilge, under the engine where anything from the engine and stuffing box collects. This bilge does not drain into the boat bilge, a feature I like since the boat bilge stays clean (relatively) and if free from oil. Third is the shower bilge, a separate bilge in the head that collects water from the shower. This bilge has a pump controlled by a switch in the shower area, and a check valve on the pump output.I am thinking of doing away with the check valve and drilling a small (1/8" or so) hole in the shower bilge. My thinking is that I will use the bilge pump to drain most water overboard and what does not drain, or leaks back from the hose since there will be no check valve, will drain over time into the boat bilge through the small hole. Is there a flaw in my thinking, or some better way to drain this bilge? I want to get rid of the check valve since it has been a high maintenance item.
