Bilge Pump
Rick
Oct 5, 2004
1,098
Hunter 420 Passage San Diego
My Hunter 33 is just over a year old and the bilge pump is not working. It is a Rule Mate 750. The light on the panel is on but the pump does not turn on. I found a reset button but it was not out to reset, but pushed on it anyway. I examined the pump and moved the impeller and the float works. Does anyone have any ideas before I buy a new pump and find that I missed something simple. Thanks
GuyT
May 8, 2007
406
Hunter 34 South Amboy, NJ
Take off the wire nuts, clean the wires, and
put the wire nuts back over the connections and check again. It may be corrosion especially if the wire nuts were in the bilge water.
Jul 23, 2007
2
- - Niceville, FL
No visable nuts connecting the wires
Thanks for the help. This bilge pump that came with the boat is a contained unit. The wires go directly into the unit, so I guess I have to tear apart and see what I find.
Similar problem
Check out the thread on the Hunter "Big Boat" forum about my bilge pump.
Jul 23, 2007
2
- - Niceville, FL
What was the final verdict
shemandr; Was your problem because you disconnect the CO detector? I have not disconnected anything ( that I know of) Thanks for the help
