Now that you found it, check the capacity of the fuse- very inportant, Rule packaging will tell you exactly what it should be.Secondly, I put an alarm on my bilge pump. Went to Radio Shack and bought a DC alarm and wired it into the bilge line so that every time it starts pumping, I can hear it topside. ( Also inserted a cut out switch on the alarm so it doesn't go off at nite when we are at port sleeping. It is good to know as you are going along if you are suddenly pumping water out more frequently. Means you should go below and check matters out.
