under the starboard side setee there is what says ( according to the paper label) to be a bilge pump. It doesn't seem to working and was wondering if this is the original one or not.It is secured to a board that is epoxied to the hull itself. It looks to be factory? There is a bilge pump and switch directly under the floorboard in front of the engine, that is the one that does work and sends water out the starboard side rear. Is this like everyone elses? Just wondering if I should test and activate the under the seat one it or leave it or remove it? It seems to have a filter of some sorts about a foot away. Not sure if its on the intake or exhaust side. Thanks
