bilge pump
1
Bayfield 25 Penticton
Anyone Please, who knows where I can find the location of the bilge pum in a Bayfiel 25. Urgenty needed. Thanks fellows
Jun 9, 2008
1,817
- -- -Bayfield
In the bilge? If not, then follow the hose that goes into the bilge to the pump, which might be located under a berth, for example.
May 24, 2004
7,202
CC 30 South Florida
Not sure about your boat, but bilge pumps were optional in some makes and models. Bilge pumps are usually installed in the low point of the bilge as this is where the most water collects. Look under the floor boards and follow any discharge hose as other have pointed out. If your boat has none then you get to choose what you may want to install.
Cherubini 37c HULL#37 Alameda
He sounded anxious in his post. :eek: Hope he was able to keep her from filling. Heads up people ! Check you bilge equipment to be sure all is still working properly and you know how it operates.
rodb
Jun 7, 2011
3
Oday M pasadena marina, saint petersburg, fl
I suggest you track every above water overboard fitting hose from the overboard connection to its ultimate destination and either tag or not each one for future reference. During this process you will either locate the bilge pump/pumps or establish their absence.
Fair Winds
