Bilge Pump
May 19, 2020
6
O'Day 23-2 Barnegat Bay
Any unique ways to power the bilge pump to run it occasionally in the winter after the batteries have already been removed? I realize in the grand scheme of things it’s not difficult to bring the battery with me and hook it up quickly when I need to run the bilge (old boat, takes on the occasional rain water no matter how many times track down leaks and fix), just curious if anyone did anything outside of using the boat battery to run the bilge.
Jan 7, 2011
5,999
Oday 322 East Chicago, IN
No need to remove the batteries if they are maintained and all parasitic loads are off. Last year, I kept mine (2 6-volt GC batteries) on the boat and wired to the panel (and main switch off). I was at the marina pretty often and had access to 110 power so I could run the battery charger when ever I was out there for a few hours.
This year, my boat is parked far from 110 power, and i don’t plan to be out there very often. So this year I just disconnected the negative wire on the battery bank, and will check it once in a while when get a chance to get out to the boat.
If you left the batteries on the boat, you could disconnect the negative wire when away, and hook it up to pump put the bilge when you are out there.
Lastly, if you have any transducers low in the boat, you could remove the transducer and stick a plastic scrubby or something in the hole to keep critters out, but let water out. Only useful if it is located in a good spot. My old boat had a speed log in a place that would drain the the water out of the boat if it got too high.
Greg
Likes: Dalliance
If lugging the big battery to the boat is the issue, then try a small 12 volt battery. Your looking for easily managed 12 volt power for a short duration.
Something like this motorcycle battery might serve the need.
12 volts, 3.09 lbs.
Attached is a spec sheet. HomeDepot listed at $18.
25
Catalina 25 Whiskeytown Lake
On the rare occasion I have any water in there, I use a similar stick pump into a bucket. It’s battery powered and half that price from Harbor Freight. For the last little bit, the baster does the trick.
Sep 24, 2018
4,690
Catalina 30 MKIII Chicago
Try a solar panel. Most solar controllers have terminals for "load". connecting your bilge pump to this will prevent your batteries from getting drained too much. You can use your existing batteries or a small one as jsailem suggested
Likes: captcoho
Mar 26, 2011
4,010
Corsair F-24 MK I Deale, MD
Install a small solar power system. No hauling batteries. No portable panels that don't last in the elements. No taking a charger to the boat. 50 W is plenty. You can probably stop plugging in at the dock; one less thing and less risk of electrolytic corrosion. Longer battery life. Easier sailing all around and fewer worries.
The simplest, long-term solution. Just keep it simple. I installed this in a few hours.
Simple Solar
