I have a new/old Oday 25 without a bilge pump. I have the components but not sure where to locate exit. Transom? Side? How high from pump?
Different boats.. Now with a C-34 that was already plumbed.. However, I had an O'day 272 that needed a bilge pump. On that boat the discharge line was run under the inboard diesel and up into the starboard lazarette and aft the transom where it discharged.. The check valve was at the pump and the discharge was high enough up the transom that following seas would not be an issue.How did you route the hose out of the bilge? Any pictures?
