Bilge Pump
Apr 29, 2012
218
Beneteau 35s5 bristol ri
Has anyone updated the tiny original one with one that goes to the bottom? I have a pump that fits into the hole in the middle and a float switch. Any advice would be greatly appreciated.
Jul 7, 2004
8,492
Hunter 30T Cheney, KS
Are you asking about a Hunter 285 in the Beneteau forum? Have pics where you want to place one?
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
Are you looking to install a larger or second bilge pump, install a separate float switch or something else? Consider a primary RULE 1500 bilge pump with a Rule-A-Matic float switch and a secondary RULE 4000 bilge pump with a Rule-A-Matic float switch, wired to high bilge water alarm.
Jul 7, 2004
8,492
Consider using smooth bore discharge hose instead of that corrugated junk that lowers the effective discharge rate
