Roger, yes
I want my pump to run, while I am away if she starts taking on water. I also am connected to shore power so I am not concerned about the batteries per say. Now I suppose you will find a set of circumstances where you set up would be beneficial. I have mine hot wired to the batteries, but I also have a breaker for the bilge in the lazarette totally seperate from the DC panel. This gives me a way to shut the bilge pump off if it runs away for some reason, because the bilge switch on the DC panel is a breaker but only has a manual and auto position. For an overheat problem I would think. My boat is a Hunter too, so check around on yours. You may already have a bilge, and master breaker installed. Mine is in the lazarette where the engine batteries are. I have a battery powered CO2 alarm so if it goes off.. oh well.Cheers
