Our 331 bilge pump seems to work only when we flip the switch on the panel. The float will not make it work at all. Checked the fuses yesterday, both were good. What do we look for now?
How do I do that?Bad float switch. Can you bypass it and see if the pump comes on?
You can jump (connect) the two wires leading to the switch.How do I do that?
Since I can't see what's there I'll make some assumptions. Most Beneteau's do not come with a float switch since the bilge is so small. Most people add a switch later. Originally mine only turned on when the switch at the panel was on. Since then I've added an electronic switch but the panel switch must be on to supply power.Our 331 bilge pump seems to work only when we flip the switch on the panel. The float will not make it work at all. Checked the fuses yesterday, both were good. What do we look for now?
Yes, its installed in the main center bilge section. Was there when we bought the boat. The only other time it didn't work was when one of the 10amp fuses blew - that we didn't know existed until then - and this forum pointed us to it.Since I can't see what's there I'll make some assumptions. Most Beneteau's do not come with a float switch since the bilge is so small. Most people add a switch later. Originally mine only turned on when the switch at the panel was on. Since then I've added an electronic switch but the panel switch must be on to supply power.
The question is , Are you sure you have a bilge switch?![]()
Thank you! My husband did some disconnecting and troubleshooting yesterday with a multimeter and all metered out fine except the run from the manual switch to the junction box which is under the bathroom sink - I think thats what he explained to me. So thats where he's going to start.Here is a PDF of the Rule Bildge Pump Wiring on my H240. It should be similar. It sounds like the float switch is bad. It is hard to trouble shoot because of all the water proof connections. You hate to cut the wires in order to use a volt meter.
