Bilge Pump Noise
Rick D
Jun 14, 2008
7,184
Just curious... I have fourtyish Benes on each side of me. Both make a sound intermittently which sounds like a diaphragm bilge pump from the outside. Both boats are new to the owners so they don't know. So, is that what it is? No water discharge I see. I was worried but it's been a while now with no I'll effect.
Jul 7, 2004
8,481
Hunter 30T Cheney, KS
For both to be making the same sound I'm thinking it's normal. But why you don't see a discharge is strange. Could both have the same failure? Maybe it's something else like a Cadillac level control ;)
Likes: Rick D
Catalina 320 Dana Point
Could it be seawater cooling pumps for Air Conditioning Rick ? I think some use a below waterline thru hull for intake and discharge.
DougM
Jul 24, 2005
2,242
Beneteau 323 Manistee, MI
could be a water sensing bilge pump. It runs a few seconds on a time schedule. If it derects water it continues pumping, if not, it shuts down.
Our air conditioning condensate pump runs intermittently when the AC is on. It's more of a buzzing than a diaphragm pump, but it pumps just a little weep of water so it would explain why you don't really see any water pumped out.
May 27, 2015
35
Beneteau Oceanis 41 Havre de Grace MD
Yep same here..Although in the early morning it does seem louder.
Jan 2, 2016
32
Beneteau 49 Little Creek, VA
If they have the electrical panel switch for water pressure on, then it may well be the water pump adding pressure to the accumulator. There would be no discharge of water. In my experience accumulators or the systems leak pressure over time such activates the pump to get the pressure back up.
Rick D
Jun 14, 2008
7,184
Thanks guys! As I said, I have concluded whatever it is isn't isolated to one boat and seems to be not damaging. So I am no longer concerned. It is a curiosity however.
Rick D.
