Bilge pump mystery
Aug 24, 2009
13
Beneteau 331 Seabright, NJ
I'm having a problem with my bilge pump that I can't seem to cure. The light on the electrical panel is always on, but the pump is not working. Whether I flip the switch or activate the float, the light stays on and the pump doesn't work. I used a multimeter and confirmed that I'm getting power to the pump when either the switch is flipped or the float is activated so I thought I must have a bad pump. I removed the pump to check for any clogs or obstructions and didn't find any.
I purchased a new pump, same specs as the old one and I still have the same problem. Light stays on, confirmed electricity is getting to the pump but pump doesn't work. Any thoughts?
Dec 2, 1997
9,011
- - LIttle Rock
Your problem is obviously electrical, not a plumbing problem (so how 'bout deleting the duplicate post there), and I think Maine Sail is the person to solve it. He's more likely to see it in Ask All Sailors than here...so I suggest you also post your question there and delete it from here too.
Sep 25, 2008
7,682
Alden 50 Sarasota, Florida
This has nothing to do with Beneteau but in answer to your question, it sounds like a high resistance connection problem which will manifest itself only under load.
When was the last time you cleaned all connections?
Jun 19, 2004
365
Island Packet IP 32 99 Forked River, NJ
I'll bet you have a bad ground wire. The circuit is being completed through the lamp. Try jumping the neg lead of the pump direct to batt (-). Pump should then run.
BTW... is your float switch on the + or the - side?
