I'm having a problem with my bilge pump that I can't seem to cure. The light on the electrical panel is always on, but the pump is not working. Whether I flip the switch or activate the float, the light stays on and the pump doesn't work. I used a multimeter and confirmed that I'm getting power to the pump when either the switch is flipped or the float is activated so I thought I must have a bad pump. I removed the pump to check for any clogs or obstructions and didn't find any.
I purchased a new pump, same specs as the old one and I still have the same problem. Light stays on, confirmed electricity is getting to the pump but pump doesn't work. Any thoughts?
