I have a Hunter 306 and recently discovered that the float switch (Seachoice 19407) for my bilge pump (Rule 800) was not working (a story for another day). The float switch was screwed directly into the bottom of the bilge and the screw completely disintegrated when I tried to remove it. So I've temporarily zip-tied the new float switch to a nearby grounding cable connected to a keel bolt. In the process of sorting all this out, I discovered that the bilge pump is not secured to the bilge at all. There seem to be several small screw holes where they might have once been installed, but I found that I did not have any luck getting a screw to easily bite into the preexisting holes.
So I need to figure out how I want to secure this stuff to the bottom of the bilge. Needless to say, I'm nervous putting a new hole into the bottom of the bilge. I've seen that some people might epoxy in a block of wood or something in the bottom of the bilge to screw into. Alternatively, the switch and pump both have detachable bases, and I thought about attaching the bases directly to the bilge with a few spots of epoxy, but figured that might be a hassle if I want to switch to a different model/brand switch/pump. And then there's the question of epoxy or perhaps an adhesive (e.g. 3M 4200). So I thought I'd see if anyone had any better ideas first.
Here are the options I'm aware of: 1) screw directly into the bilge; 2) Use epoxy/adhesive to attach wood to screw into; 3) Use epoxy/adhesive to attach device directly to the bilge. Any other tips? Anything else I'm missing?
