John Boag
Well guys, I finally tried to follow you instructions installing the bilge pump on my 1978 Catalina and had problems with both methods you suggested. Maybe I just mis-understood what you tried to tell me. I was able to feed the hose from the bilge to under the engine. I could not find the hole Nick talked about so I drilled a hole near the engine mount. I was able to snake a cable through but not the hose. I also looked at running the hose sideways out of the bilge like Rob suggested but I would be drilling right into the hull. So I need some more help. should I cut an access hole in the pan under the engine and add a cover with nipples above and below to run the hose under from the bilge and above under the engine to the stern?
