Matt Borders
I need some advice. I am trying to install a new bilge pump in my 1982 Hunter 22. What really started off the fustration was when I found the through hull fitting that was for a bilge pump (hose is about a 1 1/2 inch Hose). Well, I was wondering where the pump was. I was finally able to trace the hose. Much to my dismay there was not a pump attached to the hose. WHAT TYPE OF PERSON REMOVES THE BILGE PUMP WHEN THEY SELL A BOAT?!?!?!The next problem started when I was looking for a bilge pump to fit that very small opening for the bilge. The only bilge pump that I could find has a 3/4 inch hose fitting. The big question is what to do? Should I make a new 3/4 through hull fitting and run the hose there? I would rather get a different pump that would hook up to the through hull fitting, and it has to fit in that small space (anyone have any suggestions?).
