I'm considering adding to my bilge and electric pump to discharge any water, sea or rain...and have it electrically (via pump) removed, this may seem like a simple question, but my boat has a manual pump and for 22 years the bilge remains dry...not to press my luck, I've decided to add a Rule pump.
My question is...short of making a hole in the boat for the discharge hose to jettison the water, is it possible to use the existing Manual pump hose for both electric pump and manual with some sort of "Y" valve and utilize the existing pump discharge?...this seems pretty basic I guess, but most of what I've found shows a separate discharge hole, of which I'm not excited about drilling a hole in my boat...siphon valve etc...
thank you.
thank you.
