T J Furstenau
Okay, maybe I'm missing something really obvious here, so I'm hoping someone can tell me what it is. I get water in the bilge, which tends to happen on a boat, especially when the icebox, shower, etc. drain into there. I don't have a real problem with that, the problem that I have is that when the bilge pump kicks in and pushes that water out (which it does a pretty good job of), inevitably when it shuts off, I get a bunch of that water back in the bilge as backflow through the pump. Easy, I thought, install a check valve so that water only goes out and not back in. That's the catch. It appears that the outlet for my bilge pump (and most that I've checked) is 1 1/8 inches, and I can't find a check valve that size. 1 1/2 yes, 3/4 yes, 1 1/8 NO. So do I live with it? Is there a reason why no one would want a check valve on a bilge pump, which results in no demand, i.e. no supply?I appreciate the opportunity to vent and any insight that the wise members of this forum can shed.T J
