Bilge cracks
L
LarLei
I have an open crack in my bilge which is slowly seeping water. I can't tell if it is a pocket that is holding water, or if the water is actually coming from the outside. The fixed keel is bolted in directly under the bilge. There are closed cracks all around the bilge but are not leaking. The bolts are also staying dry. Anyone have any ideas?
A
andy
Get the boat out of the water asap
It sounds like you ran it aground hard. You have a major problem! Have a surveyor inspect it.
