The big project is redoing a soft (likely de-laminated) cockpit seat where there had been teak slats attached. I've done some fiberglass work in my life, but I've never had to do anything with a core before. I've seen several books and how-to papers on the topic, and lots of detailed posts on this forum that I'll return to before I start the work...
My first question is on core material. Should I replace what damaged core that I remove with the same type of material, or are there other coring materials available with improved properties compared to what was most likely used in original construction in 1989? I'll be working from the outside of the seat inward, do I still need to be vacuum bagging?
And once I've finished the fiberglass work, then it's time to refinish the non-skid surface on both cockpit seats and the sole as well. What's on there now is a sanded paint (scratchy seats), and a dry-deck matting on the sole (scared me big-time on our test sail when it slid out from under me). I've seen and read the posts on Kiwi Grip. I was originally considering a composite material that looks like teak (specifically Tek-Dek), but heard that there may be problems with "bubbling" (another word for de-lamination). I don't mind the minimalist grey surface on white get coat, but also wouldn't mind an occasional compliment if I manage to do a good job of installing something a little more sophisticated.
Thanks,
Dave
Thanks,
Dave
