Mountain Bike w/ Wheels Off
What works for me is an aluminum frame Raligh mountain bike with the wheels and seat removed. The wheels and seat, like all bikes today, held in position with quick-releases. For the frame part, to keep the derailleur from resting on anything, I made up a jig for support. It's a piece of 1/2" plywood about 3" wide and about 2 or 2½ feet long and has a vertical piece about 6" high at the aft end with a hole to support the kickstand and at the forward end I have a "bracket" with a quick-release "axel" screwed on to accept the front forks. The bracket is turned parallel to the frame so the handlebars must also be turned parallel to the frame. The support just keeps the main sproket off the plywood and the kickstand supports the back of the bike. This makes for a compact means of keeping everything in order.The wheels are easy to remove once the break cables are disconnected from the brakes.The frame and wheels fit easily inside the lazarette where I cover the frame with a blanket to keep the paint from getting scratched.The boat is a Hunter 35, 1988. The original lazarette went all the way into the bilge but I constructed a "mezanine" to clear the waterlift muffler and fuel tank and this provides a large and long flat surface to put things on.It's been five years now and no signs of weathering and not one speck of rust anywhere. Looks like new. It's a great piece of transportation to go to the grocery store or just to get around.
