S stevebirch2002 . Nov 8, 2001 1,818 Dec 7, 2008 #2 Hi Patrick Easy transplant. Used BZ482 (13.5hp), Beta 16 (16hp) and BD722 (20hp). All quite simple to fit into the Series II and III Vegas. Cheers Steve B
P pwhitney100 . Dec 6, 2008 17 Dec 7, 2008 #3 Thanks Steve. I assume it should have a larger propellor if I put a 16 or 20 in it. Do you know if I need to make other changes.
S stevebirch2002 . Nov 8, 2001 1,818 Dec 8, 2008 #4 Needs about a 13 or 14 x 9 3 blade prop. 16 or 20" will not fit. Must be Right Hand as well, 25mm shaft fitting. Ta Steve B
