That's funny, because I don't consider 1/4" to be thick, but this is normally just thin where the hull runs above the water line. As an example of some really thick construction, when I cut out a hole in the deck of my C 30 for a Nicro vent in the head, the core showed 1/4 " of glass at the outer deck, 1 full inch of marine plywood & or balsa wood core & another 1/4" of glass liner for the inner cabin top. The core sample was 1.5" total thickness. That would be my point as to building boats a lot stronger & heavier then todays boats. BTW oil canning can & will happen on a wooden boat, if it has wet rot in the hull. The C 30 is 10,000 lbs., empty & for a 30 footer this is considered very heavy, when compared to its contemporary 30 foot production boats such as Hunter, Cal, Pearson, etc. I believe that an average 30 footer todays weighs around 7,500 lbs, or even less. I guess this is better for performance, but it is reassuring to know how solid & stiff the C 30 is under sail. The C 27 was no slouch either, but I believe the C 25 & C 22 are built on the light side, & are easy to damage when they get water in 'em which rots out all the wooden bulkheads & supports rather easily. But its still amazing to see how many 35 - 40 year old Catalina's are still skulking around & out sailing most of their contemporaries, which were crushed many years back!
