I'm currently working on a design for a transom hung kick up rudder for a 25' boat (specifically a Venture 25). Nominal dimensions are 1 1/2 x 12, with 4' below the waterline, with a true NACA profile. I'm planning on laminating two pieces of 1 x 12 wood together. Also, I am planning to internally weight the lower portion to make it neutrally buoyant by sandwiching a piece of stainless plate in an internal pocket (I might use regular steel, as it should never see the water. If it ever gets wet, then the rudder already failed
I wish to use readily available lumber (big box store availability). This limits me to oak, maple, poplar, or pine. Of these, which do you think would be the best material to construct the rudder from? Or, would it be worth hunting down another type of wood for the project? I'm leaning toward oak, but I am only moderately familiar with the qualities of wood (I'm more a metal kind of guy
). Thanks!
