Best way to mount 6" plotter & Autohelm head?
  • Thread starter Patrick Randall
  • Start date
P
Patrick Randall
I've noticed that most of the "Navpod" installations seem to be on a a "cranked forward" pedestal guard. The one on this H30 91 is straight up on both sides with a curve on top. Can someone recommend best way of mounting a 6" plotter & Autohelm head (and maybe another tridata or something (later)) at the helmsman's position?
F
Frank Walker
No room in the inn.
Patrick, Locate the autopilot over on the stbd side just fwd of the rear berth area bulkhead. Opposite of the engine panel. I have all my ST60 instruments mounted up on the cabin bulkhead along with a compass on each side. This allowed me to remove the binnacle compass and mount my radar display in it's location. Because of the small cockpit I have found this arrangement to work quite well.
John J Frank
My Two Cents
On my 1989 I mounted my Standard Horizon plotter in a custom cut aluminum housing from Edson right in the middle of the pedistal guard using an Edson mounting bracket which attaches to each side of the guard. I subsequently, mounted my autopilot and wind instrument out to the side using smaller Edson aluminum housings and chrome pedistal mounts, again from Edson. Rather pricy, but the housings can be rotated, as well as very ergonomically located to the wheel.
F
Fred Harriman
Chartplotter at pedestal on H27
Check this photo from the forum archives to see what I did. Do a search in the archives with me as the author and you will see the threads. Fred.
P
Patrick Randall
Picture of your cockpit?
Frank, that sounds interesting. Have you a picture of the cockpit you could post? Patrick
P
Patrick Randall
picture please?
Frank, do you have a piucture of the setup you could post pls? Patrick
F
Frank Walker
In A Few Weeks
Patrick, I am on my way out of town for a few weeks and do not have the time right now to get a picture. I will write myself a note and when I get back I will take a picture and post it. Keep an eye out. Frank
