Best way to clean scuffs from floating dock on your hull?
luken7
Aug 21, 2010
96
Beneteau Oceanis 361 Oriental
So we arrived at our destination where the marina has floating docks and I forgot to put our fenders out before docking. So we have these nasty rubber marks on the hull. What's the best product and way to clean off the scuff marks? Photo attached.
58
Macgregor 26X Beaver Lake NW Arkansans
Re: Best way to clean scuffs from floating dock on your hull
Mister Clean, Magic Eraser works very good, it's a little sponge. quick and easy
We've used acetone for those scrapes for years.
Jun 21, 2007
2,118
... or if you already have lacquer thinner amongst your paint supply, it also nicely removes rubber dock edge scuff marks from the hull.
Just wet a soft rag or paper towel with the solvent and wipe off the scuffs.
Besides removing the scuff marks, acetone (or lacquer thinner) also will diminish the wax protection that is on the hull. So, depending on the condition of your gel-coat, you may notice a change in the gloss level. Just re-wax the area to restore.
A can of lacquer thinner is standard equipment on my boat for dock encounter remediation. With the frequently strong cross wind at my berth, and even with fenders deployed, I need to remove dock scuffs more frequently than I would like to admit. Actually just as many of my scuffs occur backing out before I have enough speed up for the rudder to work against the effects of both the cross wind and the reverse prop walk. The fenders cushion between the dock and hull at first, but they ride up on to the dock as the boat moves out. Then its just hull verses dock.
JerryA
Oct 17, 2004
550
Hunter Hunter 170 Sandusky Bay, Lake Erie
I usually use rubbing compound and rewax, but I will have to try some of these ideas the next time.
JerryA
luken7
Aug 21, 2010
96
Seems that acetone is the winner here. I'll give that a try this weekend as I have a can on board.
Dec 2, 1999
15,184
Luke:
Please just use a very small amount (acetone) on a clean rag. Be aware of the fumes too.
You may want to re-apply wax if you hull is waxed.
Steve's right. Read the label on the can and protect your fingers. But I do that with anything that comes out of a can from ACE Hardware --- my favorite boating store! :):):)
gpd955
Feb 22, 2006
1,164
Catalina 310 Cape May, NJ
Steve Dion said:
Luke:
Clean rag...definitely. A dirty rag will just spread the mess around. I usually keep a "box of rags" that you can get at any home improvement store (paint section, usually) so I have plenty of clean ones on hand.
I don't know if it's an ACE Hardware thing, Stu, but our ACE is well stocked with marine hardware also and I find myself buying from there as much as I do from WM and Defender.
RichH
Feb 14, 2005
4,773
The 'rubber' used on most docks is PVC. Although Acetone will dissolve most of these 'blemishes' a much better product to use is Interlux 2233N, a solvent used for 2 part urethanes and epoxies.
Joe
Jun 1, 2004
8,323
Acetone works well on petroleum based marks. For organic stuff, like algae... acid based cleaners (diluted, of course)... will effortlessly remove it. As always..... rinse with fresh water after using.
Jun 9, 2004
963
Hunter 40.5 Bayfield, WI
I had a huge scuff mark that a charter left on Emmanuel's hull last year. I used a razor blade in a hand held scraper and that worked really well. After scraping I went over the area with that 3M One step cleaner wax. It came out great. I did it that way because I always end up messing something up with solvents. Quick, easy and no smell.
Hunter 25_73-83 NORTH POINT MARINA/WINTHROP HA IL
JerryA
I agree with Jerry A. Take a very small amount of liquid medium grit rubbing compound on a wet rag and rub lightly. It all comes off with no damage to your gelocat. Follow with some spray wax. Magic. Goodluck and good sailing, Ron
luken7
Aug 21, 2010
96
I love this site. You folks are very helpful. I'm also going to start roaming the aisles at Ace Hardware.
