Best resin to use for structural work?
C
Colin
The structure supporting the fresh water tank on my h335 collapsed. I have built a replacement but now need to bond it to the inside of the hull. I was planning on bedding the structure down on #m 5200 then galssing up the side to add strength. What is the best type of resin to use for this application? The boat is an 89 vintage.
Oct 7, 2004
106
Hunter 260 Abundance - H260, Las Vegas, NV
Structural Repair
I would recommend West System Epoxy using colloidal silica to thicken it. There's a PDF file that West Systems has - look under the Projects section of their website then find the "Replacing damaged bulkheads" article. Might be helpful to you.
