Best power system for computer
Joe
Jun 1, 2004
8,351
Hi guys... I have a portable inverter(400 watt) that can be connected to the boat's 12 volt system via a cigarette lighter plug but it works much better by alligator clipping it directly to the battery. I then plug my laptop's 110 power adaptor into the inverter's AC plug.
I am thinking the system might be more effecient if I purchased a 12 volt adapter that would connect the computer directly to the boat's 12 volt socket. It seems illogical to convert from 12 volt to 110 then back to 12 ( or whatever the computer is, I don't know)
Thanks for the help, in advance.
Oct 12, 2009
63
beneteau 321 digby
adapter
for what its worth which probably isnt much from what I can gather the larger the inverter the more dc power it takes to run the inverter.for example i had an inverer which i beleive was 400 watts and im pretty sure it had a fan on it so theres more power being sapped from the batteries.what I did on my boat was I bought a cheap 75 watt plug in inverter which will run my laptop and thats about it.However thats all I want to run so im good with that.Big inverters look impressive and you may be able to run alot with them but they are hard on batteries.In my opinion when it comes to inverters less is more.Im thinking it will use more power to run your 400 inverter than it would to run a 75.The idea of going with a direct dc power source to power the laptop is most certainly the best way to go.
Oct 22, 2008
3,502
- Telstar 28 Buzzards Bay
You can buy an automotive power supply for your laptop from Targus, iGo or any number of other companies. These are designed to work by plugging into a 12 VDC cigarette lighter style accessory plug
Of them, I'd recommend the iGo units, since most of them can also double as a cell phone/PDA/DS charger as well as charging your laptop.
Bob J.
Apr 14, 2009
775
Sabre 28 NH
Alot of over the road drivers use the plug in to the cigarette lighter type of inverters, (400 -700 watt) to charge their laptops & cell phones while the truck is running down the road.
I'd look at the power draw between the 400 watt inverter that you currently own & the 12 volt type of unit to see which unit draws the least from your battery bank. You'll also need to consider the length of charging time. My experience with any of the 12 volt type of devices that we use on the road is they take longer to get the job done. Case in point, a cell phone typically charges faster when hooked up to line voltage device when compared to the 12 volt cigeratte lighter.
Dec 2, 2003
1,637
Joe,
You are right.
Put your hand on the laptop's power brick and it is warm. Then put it on the 400W inverter and this is warm too. All power from your boat's battery!
Put your hand on a car to laptop power supply and it is wasting the same amount of that as the original power brick. A single conversion is more efficient - approx half the wasted power.
MrBee
Dec 30, 2008
425
Irwin 34 Citation Middle River, Md.
My understanding, from the great folks on this site is that it would be better for your Boat Batteries to use a 12v Cig. supply instead of the inverter. That being said, i use an inverter. I chose that because I only wanted to spend ONE time and so that i could also run/charge corded and cordless tools. As to the inverter, I have a high end high power Gateway and found that If I used those 300 - 400 watt Type inverters that plug to the Cig lighter, I couldn't even use the mouse. I had to have the better output of the inverter. This works fine for me but you have to decide what your needs are.
Brian
zeehag
Mar 26, 2009
3,198
the 12 v laptop connectors are very expensive 200 dollars a piece--and last only 3-4 months--i went thru many of them before i bought a 400 wtt invertor--i tried to use it via the 12 v outlet in boat---not function--screams not enough juice-can only use that way for up to 90 wtts lol...i wired it into the boats circuitry and it works perfectly--do it this way and will work for looong time --not have to cost 200 dollars/plug lol...goood luck--i am happy with mine--i live aboard and havbe for many yrs--is the best way i have found to use lappy on board without aggravation and screaming invertors and much overhead for new 12 v plugs lol.....goood luck....btw--i felt the box on 12 v and on 120---it is warm both ways--spozed to be..just not spozed to be realllly hot.....
i tried kensington, m fuel, and hp for my hp pavilion....the hp lasted for 4 uses..lol...the kensington was 3 months and m fuel was 4 months--all from circuit city and had warantees not recognized by circuit city(after the fact , btw--) ...goood luck......
Aug 2, 2005
374
pearson ariel grand rapids
I agree, dual conversion is a waste of power.
Nearly anything that is designed to be portable will have a 12v adapter available. No reason to introduce more draw than needed to charge/use the device.
Only reason I would consider an inverter would be if I had a LOT of things I needed to run on 120v, and would have the draw regardless (at this time I have exactly nothing) otherwise the 12v is the way to go.
You can get power supplies for desktop computers that run off 12vdc, (roughly the same price as an AC version, and designed to fit in the same space) and many LCD monitors have 12vdc internal circuitry (often a 12vdc power supply) so using one of those, you could easily assemble a nice computer in an attractive cabinet designed to look 'right' in the boat, or that could be placed inside unused space to hide it.
Ken.
Jon M
Sep 8, 2009
9
1982 Lancer 25 Mk V Boston
Joe,
check out this site, http://www.laptoppartsnow.com/power-car.html?gcw=1&gclid=CPfNv8ySjqACFd1L5Qod0GpRgg
I checked for my laptop (HP Pavilion) and it was 45 bucks. Not bad.
I am in the process of revamping my Lancer 25's electrical system now and I was also thinking of this, but I might try a buck boost transformer from 12V to 18.5V 3.5A output, which is what my wall charger for my laptop coverts to. and then getting a new tip to plug into the computer and hard wiring it all in to the boats electrical system. Just a thought so far. I'll let you know how it goes!
Jon
kenn
Apr 18, 2009
1,271
CL Sandpiper 565 Toronto
If you're buying a computer specifically for use on the boat, try to find one where the DC input/charge voltage from the AC power supply is 12v or less, because the required 12v adaptor can be alot simpler, therefore cheaper.
I use a netbook (ASUS eee) in our boat and it powers at around 10.5 v.
May 6, 2004
916
Hunter 37C Seattle
I use a transformer ( $60 at Radioshack a few years ago that came with a bunch of plug in tips ). that plugs into the cigarett power socket and converts the 12 volts to about 16 vdc to run the 10 year old laptop. But I see now that most laptop battaries are less than 12 v, so maybe can run off of 12vd directly
BobT
Sep 29, 2008
239
Gulfstar 37 North East River, Chesapeake Bay
I have purchased two 12v power supplies from shopbattery.net. They are mfr & model specific for your laptop. One for my old dell, and recently a new HP. Both in the mid $50 range. I hear the efficiency is better than inverters by a factor of 10. I don't live aboard or use them for more than a few hours a week, so can't speak to longevity, but it's definitely the way to go for my needs.
Joe
Jun 1, 2004
8,351
Gentlemen........ thanks for the feedback. I have found a source for all US charts and Seatalk II nav software. TWENTY bucks!!! www.cruisingservices.net. They also offer the entire charts/software product on stick memory($40), allowing you to run it directly without installing on your computer.... very nice if you use a net book. Hope this doesn't sound like an ad, it's not.... you guys know how I feel about people pitching their own stuff here under the guise of a satisfied customer.
Oct 22, 2008
3,502
I'd point out that SeaClear II (not Seatalk II) and the US charts are all free...so if you want to pay for them, be my guest...but there is absolutely no reason to do so.
Feb 6, 1998
11,772
Kenn,
Be very careful with the eeePC's as some of them require 12V not 12.3, 14.2 or 11.6 but just a fixed 12V. Both Roger Long and I found this out the hard way.
I spent a good deal of time trying to figure this out and finally spoke with ASUS tech support. In order to hit the batt life they wanted, lots of stuff in the power path was evidently eliminated to boost efficiency. Their wall charger and car chargers put out 12V even with fluctuating incoming voltage. Targus, iGo and others do not make a charger that will work with some of the ASUS eeePC's.. I think I paid about $50.00 give or take for the ASUS brand 12V car charger..
Mar 6, 2008
1,525
Check your laptop's DC requirements. Most laptops require 19.5 VDC rather that 12VDC. I use a 75 Watt converter plugged into the cigarette lighter. Watch out as it will deplete your boat battery in about 3 hours.
druid
Apr 22, 2009
837
Ontario 32 Pender Harbour
What you need is a DC to DC converter sold just about everywhere and it is much, much more efficient than using any type of inverter ...
I'm not too sure about that. Modern invertors are pretty efficient, and since the easiest way to change voltage for DC is to convert to AC (or at least chop it), and change back to DC, I suspect the DC-DC converters actually have in inverter in them.
If your laptop runs on 12VDC or less, the battery is definitely the way to go. Otherwise... too close to call!
druid
Oct 22, 2008
3,502
Yes, a DC-to-DC power supply probably uses a high-frequency circuit to step up the voltage, but doing so is probably more efficient than the losses of an inverter combined with the losses induced by a AC-to-DC power supply.
druid
kenn
Apr 18, 2009
1,271
Good advice
Kenn,
Thanks MS. I have one of the first-generation 7" screen eee's (701, 4G), and I misspoke by 1 volt; the required DC input is 9.5v @ 2.3 A (not 10.5v).
I'll make sure that my adaptor is well regulated for 9.5 v at the required current.
