Best option for repairing sail?
7
Pearson 26 Brooklyn
Hello all,
We had a violent windstorm a few weeks back and my jib (on a roller furl) was not as tight around the forestay as it should have been. The wind got under the edge of the sail and it bellied out a bit and flapped violently for a couple of hours before my marina called me and I could come down and secure it.
It could have been worse, but the sail did sustain some damage in the section where it had opened up, about 8 square feet in the middle of the foot of the sail (or 4 feet long and 2 feet high). I resewed the stitching on a couple of the seams and it looks solid enough, but the whole area is soft and worn now, and flutters loosely in the breeze when the rest of the sail is relatively crisp and tight.
I think a large patch is in order and I have a few questions. For this situation, would it be better to sew or glue a patch on? If I use marine adhesive, will it be flexible enough to roll up around the forestay? Should I do it on one side or both? Are there any good online guides for this?
Most importantly, where can I get the material for a patch of this size? I don't have any extra sails lying around to cut up. Is there a place that sells canvas by the square foot? I could get an old windsurfing sail off ebay for (relatively) cheap, but I'm afraid it is likely to be just as worn down.
Any advice on how to proceed would be much appreciated.
Jack
Dec 1, 1999
2,391
Hunter 28.5 Chesapeake Bay
You can buy a variety of sailcloths from Sailrite, a great place to do business. See
http://www.sailrite.com/Categories/Sailcloth. You should also be able to buy sailcloth from any of your local lofts, as well. But if your sail is otherwise in good shape, I think you may want to take it to sailmaker and get his evaluation and perhaps a professional repair.
Oct 2, 2006
1,517
Jboat J24 commack
From a i have made my own J24 spinakers POV
Take it to a sailmaker for a look unless you have the right machine and know how to drive it your just going to make it a mess
My sails are worth to much money when i can take it down to a loft and have it done right for 200 dollars for a pretty compleat going over of the sail
If you dont like the price they charge then sailright is easy to get material from and has sail repiar books
BobM
Jun 10, 2004
3,269
S2 9.2A Winthrop, MA
Have you thought about shipping it to sailcare? They will reresin the sail, which will restore the stiffness and from what I understand their repair prices are also quite reasonable. The cost looks like it will be about $200. A friend of mine had his Freedom 28 main done a few years ago and was quite happy.
A similar thing happened to me a few years ago. Be warned...most repair work will cost you 50% of new. I'd call around the lofts, if I were you, as I bet you could get a new P26 jib for ~$500 given the state of the economy.
Good luck,
Bob
Oct 22, 2008
3,502
- Telstar 28 Buzzards Bay
If you can, taking it to a local sail loft is probably the best option. Fixing it yourself may result in a mess that will cost more to fix properly later on.
Pearson 26W Marblehead
other options
You didnt tell us how old the sail is? If its 10 years old or more your options might be to
buy a new one from rolly tasker. thats what I did last season for my P26W cost about $500
for a new 125% Than I sold the old jib for $125 Total out of pocket cost $375 for a new
jib. This might be a better option than putting $200 into an old one
