Does anybody have experience with life seal?
795 is not available where I am.
It is sold in Victoria. I am not at work so cannot look up the dealer.Does anybody have experience with life seal?
795 works better though - and costs a lot less.Life seal claims to be fast cure.
I had to replace my leaking fixed port lights. After I tore them off, I learned that it wasn't the DC 795 that was failing - it was very, very well adhered. It was spider cracking going UNDERNEATH the 795 resulting from the fastener holes drilled into the fiberglass, and not countersunk. Boat is 29 years old.4. Dow Corning says a lot of boat and hatch companies use DC 795. Also, DC 995 can be used and is actually stronger than 795, but why go against what's most commonly used. May as well use 795.
There ideally should not be fastener holes because there should not be any fasteners. The 3M VHB tape used with 795 will be as strong without any localized stresses.It was spider cracking going UNDERNEATH the 795 resulting from the fastener holes drilled into the fiberglass, and not countersunk. Boat is 29 years old.
So, yeah, does one need DC 995 for increased strength? In my experience, I'd have to say no.
Yes only the 795.John, Thanks for the comments and photos. Good idea using the suction cups and bungees. So now the ports are adhered and sealed with only Dow 795. Correct?
