BrianA solution of oxalic acid (wood bleach). This is available at big box home improvement stores. This is the active ingredient in boat hull waterline stain cleaner.
Have you considered a Sippy Cup?My wife frequently spills red wine on the deck. Sunlight seems to clear it up in a few days.
berry stains are broken down with lemon juice or vinegar. take slice lemon and lay it on stain for five minutes, take Mr Clean magic eraser preferably with warm water and drop or two of dawn dish soap and scrub. The magic eraser is just as important as the lemon juice. Hope it helps
The acid in lemon (citric) and vinegar (acetic) are both chemically similar to oxalic acid. Magic eraser uses melamine. It is a base that neutralizes the acid and also acts as a mild abrasive. Baking soda is also a mild base that acts as a mild ebrasive. So a follow up treatment with magic eraser and/or backing soda is a good idea to "kill" the acid once you think it is done doing its job. If you have rust stains, both citric and oxalic will do a good job. They are both capable of "chelating" the iron +3 ion in rust and thus making the "rust" water soluble. Acetic acid is better for hard water scale than the other two but is not as effective on rust stains. Similarly all three acids are effective at breaking down tannins... which are responsible for most of the brown scum stains you get in your gel coat. My personal experience has been that water scum stains are best addressed with oxalic acid but all three work to some extent.
This with the addition of baking soda, is how we get my 44 year old boat looking like new. The dish soap acts as a lubricant and makes the sponge last longer. Applying even pressure on the sponge makes it last the longest. Magic erasers are slightly abrasive so I'd be hesitant to use it on a new boat
