BEP Marine DC Control Panel
Troy Mutter
I recently posted a question regarding BEP Marine's control panel as I was considering buying and installing one in my boat. Thanks to all that responded. So I have completed the install and wanted to recommend this panel. I bought the 905NM with 24 breakers. The panel comes with 24 breakers of various sizes all installed and prewired for the indicator lighting. Installation requires the use of a DC bus bar provide with the panel for the negative side of the circuits. I thought installation was a breeze and only encountered a couple of minor problems - aside from the ugly factory wiring on my boat.:( 1) They don't send blank labels with the panel(they were happy enough to send them when I asked after getting the panel) 2) There are two small wires coming from the backlighting / indicator lighting circuit board. These were labeled incorrectly with adhesive tags but it was still obvious where they should be connected. I'll add some pics of the panel. Let me know if you have any questions about the install (Beneteau Oceanis 390) or the panel. Troy
