chafe tape
when the pole is up, take some chafe tape and wrap it in and around both the turnbuckle and the base a few times - this will hold it at the right spot forever and keep the turnbuckle from getting into a place where it will bind, even after numerous steppings. I've never seen this system fail, but I always check their condition before raising and also stop 3/4 the way up and inspect all the cable connections 1 last time b4 full step.Another thing i did was add the foot long pvc tubing w/endcap to cover the buckle and shroud, and then butting up against the endcap i started the plastic shroud cover installation, so the entire system stays stiff even when the mast is lowered. All my shrouds have the plastic covers and I found this makes them stiffer and easier to wrap and unwrap during the setup. The above 'improvements' plus the sewn on white leather spreader covers make for a thought free process.Brian
