Wire saw
Thanks, Ed. That 5200 is tough stuff.I've done all the time consuming stuff, remove the battery box, remove the bad water heater, remove the nuts from the strut scres, I think I'll see what the yard guys can do about removing the strut.Trying to contact Dahmer Marine for a new strut. Sounds like a waste of time and money to try and straighten the old one.Oh, by the way, got that sink gate valve off after applying a little heat. Turns out the gate was broken. All gates are now off the boat, I feel better.I have a rigging question. I just reinstalled my spreaders after painting the corroded tips in preparation to step the mast.The upper stay was wired to the spreader tip with monel wire, but I'm not sure how tight that wiring should be. I tried to get it tight, but the wire did not seem that strong. Should that wire hold the stay fixed at one spot, or is it alright for the stay to be able to move?Thanks
