Hurricane Damage
Replacing a strut is a bolt on change out, assuming you can get the parts from Hunter. You should check the shaft and shaft coupling at the transmission for alignment. I believe it has a one inch bronze shaft keyed into a steel two part four bolt flange at the transmission. The shaft log, and stuffing box where the shaft goes throught the hull should be inspected to seee if they are damaged. It is easy enough to remove the shaft if the flange bolts are not too rusted. Once you are installing the straightened or new shaft, cutlass bearing and strut , you should be able to see if the motor mounts are OK when you are doing the shaft alignment. The rudder on a boat that old should probably be replaced, but again, as you remove the original , you should be able to determine if there is related damage to the hull and the stern post thru which the rudder post passes. Good luck.
