Beneteau hull deck joint
Jul 1, 2015
4
Beneteau 461 ?
Hi , We are looking at a Beneteau 461 and I am doing some research on the boat.
I would like to know what type of hull deck joint this boat has, have heard comments that the Beneteau has a lousy joint......
Any comments or suggestions as to where I can find this information.
Thanks
karimari
kari, have you considered Google or any other internet search engine? They usually find information like that very well. Good luck.
Feb 6, 1998
11,722
Thanks
karimari
Most of the Benes I've worked on over 42' have an inward flange that is through bolted.
Jul 1, 2015
4
Beneteau 461 ?
Thanks this is just what I needed to know..........and thanks for the heads up on Google Books , never knew it existed .
Karimari
Jun 24, 2014
45
Beneteau 461 Kent Narrows, MD
The sort answer is "A Leaky One"
I have a 2000 Beneteau Oceanis 461. I have a substantial leak at the starboard side bow. Which soaks the V-berth, book shelf, etc. But it only leaks when I am in heavy weather off shore. When the boat bounces off the waves. It must have some hull flex which lets the water in. In the marina in heavy rains or with a power full water hose no leakage shows.
I do not believe the deck is bolted through with a bolt & nut. Rather held together with wood screws. That's what the Beneteau parts page shows ?!
I am now returning the boat from a winter trip to Florida and the Bahamas to the Chesapeake Bay. As soon as I get home I will look into this annoying leakage problem.
Any advice is very much appreciated.
Peter Breit
"Belvedere"
Gunni
Mar 16, 2010
5,937
karimari
You have to be careful when considering comments, that way be pirates and boat salesmen!
Beneteau 323 Annapolis MD
[QUOTE="PeterBreit,... I do not believe the deck is bolted through with a bolt & nut. Rather held together with wood screws. ..."[/QUOTE]
Peter, you can always look in the lazz or anchor locker to see the hardware. (You missed the IRS Cruise.)
Nov 8, 2010
11,386
Some smaller Finot-designed Firsts use a combination of adhesive, screws, and bolts into the toereals to secure the joint. The screws and bolts are on alternating centers. I actually was rather surprised to hear of the screws (on a boat I own!), so I contacted a friend who is a designer for Cong-Finot. He said that the screws where primarily there to hold the deck-hull together while the adhesive set, and the toerail was added later. He also told be that J-M Finot owned (and sail the crap out of) one of these boats he designed and approved of the construction technique. That made me feel better, as well as made me smile, thinking of the grand old man thrashing through the Brittany surf with tiller in hand and a pipe in mouth. The biggest one I know of that does this is the First 300 Sprint (not sold in the USA)
