Dan Bottjen
An '84 Beneteau First 38 fell over in a strom when dry docked, broke it's mast. The "bolt on" keel stayed attached to the hull, but there is a visible separation of approx 1/4" between the top face of the keel and the hull bottom at the forward end. The keel bolts have been sitting in water for quite some time and are visibly rusted. 1.) Is this just a matter of replacing keel bolts and bolting them up tight?2.) Is there supposed to be a physical bond between the keel and hull bottom?3.) What type of material should the keel bolts be made of?4.) I have a bid from Charleston Spar for a new mast, getting a price from Seco South for the standing rigging, is there an "O.E.M." for Beneteau sails or should I go to a local sail maker?Thanks for any input!Dan Bottjen
