Beneteau First 310 water pressure
Oct 1, 2010
8
benteau first 310 oklahoma city, ok
I have a Beneteau First 310 and am experiencing water pressure problems. Both my sink and shower have very little water pressure. I have checked the strainer and it is clean. Do I need a new pump?
Have you removed and cleaned the strainers inside the spigots? Have you removed the pump outlet and tried to see if there is pressure and water flow?
Nov 24, 2012
586
And assume you've cleaned the fresh water strainer at the pump?
Is still problems take the strainers off of the faucets and if little or no pressure then rebuild the pump.
