Beneteau First 305 Update + More Questions
Apr 28, 2016
23
MacGragor 26m whittier
Hi Guys,
So I made an offer on and it was accepted for the Beneteau First 305. Did the inspection and the hull looks good, paint job will probably last another two-years.
Here are some buyer questions I could use your help with:
1) The broker said for $25 she will get a lien report from USCG but I wanted to know if that was a sufficient way to check for liens on the title or is there no sure way?
2) Broker also said $300 for USCG certification; I visited the website, seems like I can locally register it in Alaska w/o going through USCG and save me $300?
3) Because I am paying cash and don't have the luxury of the bank charging me to run through a title service company should I add a clause on the bill of sale that says any future liens discovered are the sellers responsibility?
Technical Questions:
1) During the inspection the inspector pulled on the propeller shaft, as did I. We both saw movement when jerking the propeller shaft up and down but that is all it was, movement. Now, the inspector recommends I get that fixed but the broker thinks the flex is within normal operating parameter and I probably don't have much to worry about. So, who's right?
2) I am discovering that the world of 'boat yard work,' is crazy. Boat setup fee, blocking fee, jumping on one leg fee, travel fee from dry dock to slip fee, etc. As a result I am skipping dry docking the boat to repaint (since it will last 2 years) if I can get away with no issues regarding #1. Seems it's cheaper to get someone to go to a slip to fix 'above water' issues that the boat has then to pay the lift fee, dry dock fee, stand fee, setup fee, etc.,
Feedback appreciated!
Lastly, I have young kids, one of the things I want to do is install a 'net' type lifeline (maybe 2-3 feet high) on the aft side, is that something I can purchase online or would i have to DIY via homedepot or something?
Catalina 320 Dana Point
Anyone can get an "abstract of title" for $25 from the Coast Guard on a documented vessel.
It actually only costs $84 to transfer the title to you if the boat is already documented, the $300 was probably to have a documentation service do it for you. The seller merely signs off on document and you submit it and request for transfer to the NVDC.
http://www.uscg.mil/nvdc/instr/fee sch.pdf
http://www.uscg.mil/nvdc/nvdcfaq.asp
My personal opinion on these things: Teach Your Children Well. Teach the kids to stay in the cockpit,m never go out of the cockpit without you AND being tethered, and never when moving until they're older.
I answered this question earlier today on sn:
I'm in the position of having to replace the stanchions on my boat (an S&S 34). The existing setup uses 24 inch high stanchions, which I believe is pretty standard. I'm considering going to 30 inch stanchions. Curious if anyone has a view as to the utility (or non-utility) of taller stanchions.
The general view is always higher is better. However, if you change the height of the top lifelines, whatcha gonna do with the bow & stern pulpits? It won't look too silly at the bow, but the stern sure will.
OTOH, the very best advice I've ever read (on CF) was: "Treat the edge of your boat as a 500 foot cliff."
"Depending on "life"lines to "save" you is a fool's errand.
Good luck.
The broker wants to move the boat. The "inspector" (surveyor) works for you. Who do YOU trust? :)
Congratulations on your new boat.
Welcome to our world.
1. Learn DIY - it's safer and you'll know it's done right.
2. Your favorite "marine" store should become your local ACE Hardware store. Really.
May 12, 2004
1,505
I am not a lawyer, but since your offer was accepted you now have a contract. To amend the contract now, would, IMHO, require the consent of the other party. That clause should have been part of your original offer.
