Foot pump
The foot pump on my 285 does indeed do both of those things.There is a valve on the thru-hull, right next to the foot pump, which will select the ice box or sea water. The ice box drain function is usefull. This way, you can pump the water out of the ice box, and dont have to drain this water to the bilge, and then pump it out of the bilge. The sea water function is also usefull.The pump sends the water to the spigot at the kitchen sink, either way. Ivan (e_ivan@bellsouth.net)
