So this is what I am doing after getting some info from Beneteau and few other sources. I am installing two Marine Aire (www.marinaire.com) AC units with designated water intake sea-cocks and cooling pumps. One, 16,000 BTU, located beneath the main cabin starboard settee in front of the bulk head. I will have a 6" duct going to the angled register located on the starboard shelf over the settee. Right before the register, I will have a " T" connector taking a 5" duct to the forward cabin, with a 3" split for a small round register in the forward head. Have not decided yet about the size and the location of the supply register in the forward cabin. Also, I still have to find the location for the sea-cock and the cooling pump.
The second, 9,000 BTU unit, will be located in the starboard cockpit lazarette. Return air register on the starboard bulkhead in the rear cabin. I will run a 6" duct splitting into a 4" (going to the galley) and a 5" duct to going the rear bulkhead of the stern cabin with a 3" "T" to run 3" duct going to a small register in the rear head. I might install a cooling pump right behind the engine, unless I will find a better spot.
As for the shore power, I have installed a dedicated (second) 30A line with a circuit breaker panel located over the rear bulkhead shelf in the galley. This was an easy install from the starboard cockpit lazarette.
I will try to find all the supply air registers with dumpers, so i can control the flow between different zones. I will try to post some photos as the project progresses. My boat is in Kenosha, WI, being stored outdoors, so I have to wait for little warmer temps to keep on going. I would welcome any comments and suggestions.
