Hi,
I am fitting a Raymarine autohelm linear drive. The stock arm needs to be lengthened to suit a 240mm length. It must have been designed for an older model autohelm.
So I concerned that if I remove the stock arm which also means removing the sector, there is nothing holding the rudder and it might fall to the bottom of the sea! If I need to remove the stock arm, what holds the stock in the rudder post from falling out?
Thanks,
Mal
Thanks,
Mal
