Beneteau 375 rudder lower ring
Mar 30, 2014
28
Beneteau First 375 qc
Hi, rudder has been removed on my first375 and I'm looking to remove slight play in lower rudder bearing.
Rudder bearing seems to be made of bronze or copper thin ring directly laminated in rudder tube.
When removing the rudder, I noticed that there is a kind of thin black coating or layer on the inside of the ring...probably a coating to make a good interface between bearing and stainless steel part on rudder post.
Any idea if it's stock or something added by a previous owner?
Since the layer is slightly damaged, what kind of material should infuse to replace?
Thank you in advance!
Nov 23, 2009
437
Beneteau Oceanis 361 Clipper --
Bronze ring laminated in rudder tube and stainless steel part on the rudder post. That's exactly the same with Beneteau 361 too. But that black coating???? Probably clean first everything, assembly and check if it looks OK before adding a new layer of that thing. Maybe it's not necessary. Of course it's always a good idea to ask Beneteau too.
Nov 23, 2009
437
