Thanks for the follow up.
Mar.3,2001Dear Gary,Now that you have sourced the leak to the rudder post and it does not appear to be a problem with the seal I have a follow up inquiry for you. I noted in your commentary that the problem occurs while motoring but you made no comment about it happening while under sail. Obviously you can sail at the same speed your motoring at, the difference being that the prop wash puts more stress an the rudder. My question is have you actually observed the leak? Is the water coming out the top of the post? My concern is that you may have a stress fracture in the tube that needs the extra stress put on it by motoring to become active.Second, has Beneteau made any comment? If it is a short tube issue as you suspect will they provide a replacement?Brian Pickton,aboard The Legend,Rodney Bay, St. Lucia
