Beneteau 361 travel tower gel coat cracks.
Feb 1, 2019
13
Hunter 380 transit
Looking at 2001 Bene 361 Love the boat layout size etc. it has gel coat cracks around each traveler mount either side of companion way. No moisture checked with high quality meter. Do 361s normally stress crack there? Should I just move on? There are some othe cracks at mast base but also no moisture.
Gunni
Mar 16, 2010
5,937
Fifty, like scars on fine, well-used leather.
Apr 8, 2010
2,235
I would worry (some) more about cracks in a high stress area like the mast base... check to see if this model has any history of support weakness on the inside. (there was a Ben 361 that used to club race all the time out of our YC, and it never had any problems.)
As for traveler mounts, if the cracks are where the plinth makes a vertical turn up from the cabin surface, those are sometimes areas with thicker gel coat on many boats and thicker areas will show show some cosmetic cracks as the surface continues to cure and slightly shrink over the decades.
I would not be put off; it's stuff for a surveyor to look closer at among all of the areas he/she will inspect. Do you have some pix or a link to post?
Here is a link to a great surveyor site.
http://www.almsurvey.com
And a detailed list of things to check on. I find it useful, over the years.
http://www.almsurvey.com/faults-7/common_faluts.html
Tiny little cracks like that are best dealt with by using Captain Tolley's Creeping Crack Cure. Or by re-glassing. Tolley's is great stuff.
Jun 21, 2004
3,104
Beneteau 343 Slidell, LA
I have some crazing on the traveler mount also. Cosmetic only; no worry.
NYSail
Jan 6, 2006
3,178
Beneteau 423 Mt. Sinai, NY
Our experience several years ago with the "Captain" was that it would turn black after a while...... Again this was several years ago and maybe the formula has changed.
Greg
