Stan
I have had water collecting in one of the honeycomb compartmentsbelow the sole plates. The water typically doesn't rise high enoughto flow over to the sump, so I always seem to have water under thesole plates. What I discovered this week was that water, either saltor fresh, in the boat actually drains into voids below the bilge linerand that only when enough water is in those voids does it flow intothe honeycomb compartments. Apparently this the design because ifyou check the weep holes below the starboard side settee and under thegalley sink you'll see these holes going down ino this hidden bilge.I hate having water in the boat, even a little, but there appearsno way to get it out of there since it never gets to the bilge pumpin the sump area. Does anyone have any ideas?
