Phil_Ben361
I often wonder if my 2 blade fixed propeller is adequate for the boat (and if it is the correct size) and what more a 3 blade propeller would offer besides more drag if it is a fixed one or more costs if it is a folding. The boat is a Beneteau Oceanis 361, engine is Volvo Penta 29hp, gear ratio is 2.35:1, the 2 blade propeller size is 16X11 and I can get the following figures when motoring AGAINST 13-14 knots of true wind (17-19 apparent depending on speed) and a little bit of chop:
At 2000rpm speed of 4,3 knots.
At 2500rpm speed of 5,2-5,4 knots
At 2600rpm speed of 5,9-6,1 knots
At 2800rpm speed of 6,5-6,6 knots
At 3000rpm speed of 6,8-7 knots
Maximum rpm is 3400 and speed 7,6-7,8.
“Cruising rpm” I like to use is around 2600. If I have to motor against heavy seas I would not like to exceed 2800rmp. Above this there is a lot of noise and vibration plus increase of consumption, not the best if I have to make a long trip since my fuel tank capacity is only 75 litres. Of course speed drops a lot in heavy seas but I haven’t made a similar test to check it.
What do you think of these figures?
