Beneteau 343 Rig Tension
DougM
Jul 24, 2005
2,242
Beneteau 323 Manistee, MI
For openers, try setting the tension based on the able diameter. use the numbers shown on the box the Loos Gauge came in. That seemed to work for me. I set the lowers first. then the uppers. I paid attention to keeping the mast in column. Adjusted the split backstay last. My 323 has no adjustment in the length of the forestay, so I don't have a lot of control over mast rake. I check and doublecheck the gauge readings several times. At least I seem to get a fairly consistent setup from season to season, and the boat trims out equally well on both tacks.
