Greetings been a while. Great group.
My swim platform teak inset in my 2002 B331 has been loose for several years. Just one side so water gets under there and it kind of squishes out water as you step on it. Getting reading here in Chicago to get into the water for another start to hopefully a great season.
I noticed it really not too thick and was told an replacement was not available. Which is fine as the present one is on solid shape just loose.
I'm thinking to do the repair proper I should gently pry up the insert and clean the pocket and insert.
What adhesive would you recommend to hold it back down. I was thinking epoxy and weight it down (couple buckets of water on a plywood base).
Epoxy is permanent but would but overkill? Another option maybe be 3M 4200 which I jut bought a big tube to re-chaulk my stainless prop sleeve to the hull.
Thanks.....Craig
Thanks.....Craig
